ForzdaManger
- Aug 30, 2015
- 0
- mazda
I hope someone can help me out on this one. Hope this post isnt too long. Recently bought a 1994 mazda b2300 4 cyl 2.3L. After about 2 weeks the check engine light came on and stayed on. The truck then started to bog down and have no power sometimes. (not always) I used my scanner and got o2 sensor, maf sensor, restricted egr flow, and failure in cid circuit. I checked the egr hoses and they were filled with powdery substance. i figure some kind of corrosion. So replaced those hoses along with the o2, Maf, egr pressure differential feedback sensor and tried to clean the egr system. Ran scanner and then only got failure in cid circuit, voltage not what expected at egr pdf sensor, and failed low rpm test. I installed Camshaft Position Sensor and the check engine light went out and she drove much better, but sometimes would still bog down. I Then cleared codes.
Then Check engine light will come on and off while i drive. I ran the scanner again and now all the same old codes o2, maf plus tps. The haynes repair manual says to check voltage of the tps should be about .5v to 1v at idle and go to 5 all the way open but i was at around 12. also the resistance was way out of parameters .
Then sometimes after turning off the engine it would not start for a while.
So I replaced the tps (old one did NOT want to come off), and the Idle air control. Because i read on this forum that the iac would cause these problems with out giving a code sometimes. Same old stuff!
two nights ago it cut off going down the road and left me stranded- (walked about 9 miles). Next morning it started up and let me get about 5 miles before cutting back off. In about 10 minutes it started back up. Drove another 5 miles or so and cut off. After about 5 minutes it started up and drove the remaining 35 miles home but with very little power. At one point i was going 25 mph going up a huge hill.
Many times when I started her up I noticed the presets & clock on the radio had been reset like the battery had died. Once with the hood open i turned the key and heard a click or spark sound and it immediately started but the clock was reset. So here is my questions. Do you think i have a pcm problem or wiring problem? What would cause the radio to reset? How can check or test to find out?
The last scan i did got - KOEO 335 CONT MEM 172 336 337 KOER 116 172 336. Are all of these sensors not within correct voltage because of Pcm or wiring or both?
I have the 1994 mazda body electrical manual but need the engine electrical manual i guess.
