93 Regular cab 2wd 351 swap coil springs
19Walt93
4,464
Canaan,NH
351
3"
235/55R16
What's everyone using for front springs to hold up the weight of a V8? The truck had lowering front control arms when I bought it and had been built as a drag truck with a 302 that I sincerely hope was never raced based on the shoddy workmanship I found. I think I can live with the lowered suspension but I need more spring to get the camber within reason. I'm thinking 2wd supercab springs for a v6 with a/c would be the stiffest option. Opinions. please.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Explorer or ext cab plow coils...or a 2 over.
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
When I did my V8 I did exactly what you're thinking... extended cab V6 w air coils... and it worked well on my standard cab.
That said... I have new in the box MOOG CC870 coils and a set of energy suspension spring isolaters that I have no plan for currently.
Ramcharger90
1,708
N/A na
306, Bcam,
I used belltech 2inch drop springs in the front i just need the sway bar and it should work even better
Bird76Mojo
1,265
IL
A 1993 Ranger won't have control arms...
Check the classifieds for coil springs.
19Walt93
4,464
Canaan,NH
351
3"
235/55R16
OK, I beams or traction beams if it was a 4x4. Being aftermarket pieces they're not I beams, they're tubular.
Steakneggs
F4rtm0n1t0r
Once you find Moog's part number for any stock Ranger coil, you can go on Moog's master list and find every coil they make, with dimensions and load ratings. Doesn't give applications, but that doesn't matter. As you go up in spring rate, you can come down in installed height, or if you start talk and trim, the more you cut the more you'll increase the effective rate.
19Walt93
4,464
Canaan,NH
351
3"
235/55R16
Thanks, that's good info. The Ford parts listing used to list load ratings but they stopped, I think because they consider it sacrilege to modify a vehicle
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I checked moogs site and couldn't come up with a master list. Do you have a link?
smilinjack
34
rochester, mi
ford ranger
408C
2"
Always bite off more than you can chew!! :)
Hey guys, been doin the research lately and found the Moog CC866 is rated at 1650lbs. Stock V6 springs are 1447lbs. This works for my Cleveland transplant, they are each about 200lbs. heavier than stock. Then I called O'Reilly's to order and they no longer do Moog! They now carry
Precision brand (prob. same unit, new sticker, more money!) Anyway new numbers are Precision #SP08175Pre (1650lb) or SP08154Pre (1447lb.)
Hope that helps
scrapper
63
central IL
1975 302
check ebay or rock auto. let people know what works.
insaneranger
42
Tennessee
302
225/40 R18
If the coils don't give the support you need, adjustable air shocks might help. I used them on my ranger for a couple years because of the extra weight before I swapped to air bags. They helped a lot with stability, but I was still using stock coil springs at the time.
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
You can just stick a football inside the springs...
36974
:icon_rofl:
19Walt93
4,464
Canaan,NH
351
3"
235/55R16
I used the 1447lb springs with some stiff Gabriel shocks on mine and it actually sits a little high but I assume it'll come down some after a while. It's a 351 W with cast iron manifolds and a C4.
