TomTom59
- Jun 5, 2010
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
Last Monday on the way to work the Ranger shut off on the freeway. Had it towed home and looked it over. The rotor wasn't turning when the engine was cranked. I pulled the distributor (have never done this before on any vehicle) and found two worn teeth on the drive gear. (The bushings are worn and the rotor had so much slop the toothed inverted wheel that triggers the PIP hall sensor was hitting the sensor.) Got a rebuilt unit and installed it.
After I had owned this truck for a good while I discovered that someone had managed to break off the timing index marker. This has made it very tough to figure out TDC. Tried the finger-over-#1-spark-plug-hole but don't know where the rotor is supposed to be pointing when #1 fires. I marked the firewall directly inline with the PIP socket so I know the distributor housing is sitting in the position it should be in. The first time I tried it, it wanted to almost backfire through the exhaust so I moved the rotor 180 degrees and tried again. It cranks but does not start nor does it try to backfire anymore. Strong spark. I may have shifted the spark plug wires one place all the way around, don't know (in relationship to the vent cap on top) what wire goes where. I could use good photos of the rotor position ready to fire #1, and a diagram showing the distributor wire numbering including the vent.
I'm lost and don't know how to proceed. What I wouldn't give for a mechanic buddy right about now! My back is telling me I spent too much time today lying across the engine working on the distributor. Everything is tough to get to for sure.
