lucasruble
- Jan 13, 2011
- Reaction score
- 2
- Location
- Olympia, WA
- Make / Model
- Ford
- Engine Size
- 4.0L
- Manual
First off, I have noticed that when I fire it after cool down (such as the next day
), it will run slightly rough until I supply fuel, then allow the engine to regulate idle. I'm pretty sure this roughness is tied to my stalling/dying problem. Anyway, on to the main issue..CEL will come on intermittently and stay on for awhile, then shut off for awhile, then back on..etc.. When CEL is on, truck runs fine, but will intermittently die at idle. However, when CEL is off, while driving, it will intermittently miss, or lose power, at speed. It's a real quick miss and it doesn't happen consecutively, but will happen more than once, depending on how far I'm driving. Also, with CEL off and accelerating from a stop, it will sometimes lose power for a moment. After the quick power loss, it bounces right back and I can continue accelerating. I have tried a different TPS, cleaning the IAC & MAF, pulled some KOEO codes (KOER test won't initiate, so I can't get those codes), and checked a little for obvious vacuum issues. All to no avail. Any ideas?
