93 2wd to four wheel drive conversion
Axle_tek
Has anyone put a d35ttb under a 2wd frame? If so what did you have to do with the mounts?
franklin2
1,752
Virginia
I think I read the frame is different and it won't fit. I think people do swap in custom solid axle setups with custom leaf spring mounts.
scotts90ranger
4,329
Dayton Oregon
2.3 Turbo
Solid axle would be easier to swap in. The engine crossmembers are different between 4x2 and 4x4 so that makes it a pain since it's riveted and welded in place. Not saying it hasn't been done, but it's not easy... The easier method is what I did, I found a rolled Ranger of the same body style and engine size and swapped my then straight body on it... That way you get the transmission, transfer case, matching ratio axles and drivelines all in one shot...
That said, I'm stubborn and am planning on putting a TTB D44/D50 hybrid under my V8 Explorer... I'm just gonna plasma the junk that's in my way out and make something that fits...
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
6-7” front maybe 3” rear
33x12.50-15
I did it. There is definitely a minimum tool requirement and some basic fab skills required. It's easiest to destroy the frame in the donor truck and 2wd crossmember in your truck. It is not easy to cut the welds from the engine crossmember to the frame rails. If you are not capable of uniform out of position welds, I would not attempt this.
ericbphoto
Overlander in development
16,546
Wellford, SC
6"
I could say a lot of my welds are uniformly out of position. :icon_twisted::icon_twisted:;missingteeth;
DRanger024
482
Dale, WI
Solid Axle Swap 4x4
33x12.50-15
Bronc3
ASE Certified Tech
23
Zero Gulch, Floriduh
Supercab FX4
3"
I cut out the cold rivets and carbon arced the welds from the crossmembers and rewelded and replaced rivets with bolts. A lot of work, but the truck aligned perfectly.
Shadowrider6661
D RANGED
ASE Certified Tech
129
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
Did you know that with a little practice, its possible to was steel with a cutting torch ? I was taught how to wash steel back in the late 80s by an old timer that worked at the Philadelphia Shipyard. Its one of those things that has gotten lost over the years, not many people are aware of this dying art.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
In the context of this application it's cheaper to buy a body saw or use a sawzall.
You dont have to reweld the k member ..can be all bolt in.
Whether or not it's worth it depends on whether or not your content with the current power train. And end goals.
Shadowrider6661
D RANGED
ASE Certified Tech
129
Stock
4"
N/A
33 x 12.50 x 15
I apologize for the misspelled word, not (was), (wash) steel. Its easier than you might think. It removes unwanted factory welds when you join frame sections together,
