92 Ranger XLT Single Cab LB 2.9L 5 Speed 8.8 Open Diff with 3.55 Gears 31 x 10.5 r15 Wheels and Tires and a 4" Lift
gaz
656
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
As said, either 3:73 or 4:10 will be better than 3:55. If you think you may ever use bigger tires, then get the 4:10's. I vote for 4:10 even if both are available with 31.5".
There are many axels in wrecking yards, they will let you look at the gears, if they look nice and money permits, but the entire axle, brake to brake. Then rebuild it with all new seals, bearings, fluid and gaskets.
It will still be much less expensive than new gear set and will offer many, many years of reliability.
00t444e
217
Southern OH
Ranger ext cab
I would put 4.10 gears in and a Lock Right locker in the rear.
