92 ranger 4.0 liter.
PierreP
Lumby BC Canada
I'm stomped. My ranger was idling rough and running extremely rich, leaving black sooth on the ground. Since everything else seem to check out fine I decided to change the crank sensor... After doing so I could not start the engine, so decided to put the old one back on, still won't start. I changed the ignition module and that didn't help. I swapped the coil packs, even if the original one tested good, still won't start. I have fuel going in, sparks and the voltage is always above 12 volts. The only time that it is trying to start is at full throttle, then the intake manifold gets totally flooded. I had to syphon fuel out of it. I let it dry out and unplugged the fuel pump switch on the passenger side off, to try to clear the flooded engine. After all this, I plugged the pump switch and made sure everything was connected properly... still no start. I'm usually pretty good with this kind of stuff, but this time I don't know what to do. If I understand correctly the ignition module would be able to start that engine and keep it at 10 degrees BTDC as long as the crank sensor and the coils are good. I
I'm stomped.
8,296
Welcome to TRS :)
A few simple tests
When you turn on the key the CEL(check engine light) should come on, that means computer is powered up
When you try to start engine, the CEL should go OFF when engine is turning over, that means Crank sensor is working, computer "sees" timing pulse
On the 4.0l Engine, behind and below alternator on lower intake is the FPR(fuel pressure regulator) it has the Fuel Return hose attached AND a vacuum hose
Remove the vacuum hose and check if there is gasoline in it, if so FPR is bad and you are sucking raw gasoline into intake via that vacuum line, not an uncommon failure
All Fuel injected engine computers have the "Clear Flooded engine" setting
Turn on key
Press gas pedal down to the floor all the way and HOLD IT DOWN, 0 rpms + WOT(wide open throttle)= shut off fuel injectors
Then try to start engine, still holding gas pedal down
It should not start or even fire, there is spark but no injectors/no fuel
Crank engine for 5-10 seconds to dry it out
Release gas pedal while still cranking and engine should start now that its dried out
If engine fires or starts with gas pedal to the floor then you have a leaking FPR or leaking fuel injector
1994 and earlier Computers have 2 or 3 capacitors that can fail and leak, under $5 to replace them
These can cause all sorts of fuel issues, since that's what the computer controls, fuel
1994 and earlier Rangers have separate spark modules, computer just controls fuel
Inside of computer seen here: http://www.auto-diagnostics.info/ford_eec_iv
3 Blue capacitors are easy to see
Always worth a look, because you WILL need to change them at some point
PierreP
Lumby BC Canada
Welcome to TRS :)
A few simple tests
Turn on key
Thanks Ron, I greatly appreciate the information. Now I know both of my crank sensors are working... I will check the FPR and the capacitors and update this thread with the results.
PierreP
Lumby BC Canada
Hi! Just an update. The fuel regulator was leaking badly into the intake manifold. After replacing it, I needed to put a fresh set of spark plugs because the ones I put in previously were so gummed up. The Ranger started right away and is running like a top. Thanks Ron!
8,296
Good work (y)
Thanks for the "thanks" and THE FIX, it WILL help someone else down the road
Kirby N.
March Truck of The Month
