91 ranger 4.0l with 92 explorer ecm
Bodie1991/4.0
Firefighter
Washington
Ford ranger
Definitely leaking somewhere then. It should hold pressure for a very long time. At least overnight.
Do you know if the fuel pump has like a check valve or does it use the pump to store pressure? I guess better yet what holds the pressure?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
5,302
woodhaven mi
FORD mostly
BIGGER
sawzall?
yup...lil check ball dealio.
so there could be a restriction causing a volume issue under load.
gaz
729
Wa, Bremerton 98310
Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
Ranger 5sp, BII A4LD
Ranger 32"/4:10LS, BII 33"/3:73LS
The fuel pump pressurizes the fuel rail, the pressure is maintained by the fuel pressure regulator.
TexasDuck66
July Truck of The Month
25th Anniversary Merch
