89 rear end fix
Demose
After buying 4 rear ends decided to use the 96 but 4x4 wont work with it. It is 3.73 but much heavier than the original one and doesnt fit with front end.
3.73 7.5 very hard to find. Need the 4x4!
Any help?
Demose
Any help?
Oh. I meant to say. The mechanic says yoke too big on 96.
tinman_72
136
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
You can expand your search to include 8.8 rear ends. 7.5 and 8.8 mount the same.
ericbphoto
Overlander in development
16,593
Wellford, SC
3.0L
6"
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
Or take some measurements an talk to an experienced parts counterman about a hybrid joint, small on the shaft side and bigger on the yoke side. Just hang on to the part number for the future.
scotts90ranger
4,367
Dayton Oregon
2.3 Turbo
All you need is the yoke on the driveshaft side, should be same size U joint, should be able to swap that with a hammer and a 3/4" socket... should be available at any DIY junkyard in many vehicles, namely 1990 up Rangers or most Explorers.
