89 ranger A4LD question
forddude92
marshall texas
ford Ranger
I'm sure yall are tired of this question, but i have only owned mustangs and 1 96 ranger with a 5 speed with 360 miles on it. NOW i have a 89 ranger 2.9 with and A4LD for my kid to use as a work truck. it needs a trans and i just wanna know what years will work with this? will a 4.0 a4ld work?
8,369
Welcome to TRS :)
1989 to 1994 A4LD will work as far as the wiring, 1986-1988 had different wiring
If you have a 2.9l V6 engine then yes a 4.0l A4LD will work
If you have a 2.3l(4cyl) then it would not work
Also 2WD or 4x4 have to match, no conversion is possible
forddude92
marshall texas
ford Ranger
Welcome to TRS :)
thanks so much!! that helps out a lot. If its from a 4.0 explorer, is everything the same, bell housing and tail shaft?
8,369
Yes to both, assuming both are 2WD OR both are 4WD
lil_Blue_Ford
6,091
Butler, PA, USSA
4.9L
Well, what are we dealing with here? OP mentions 5-speed and A4LD… which are we or are we planning a conversation from manual to auto? If it’s a conversion you need the trans, flex plate, starter, engine harness and computer.
If you have the A4LD auto already, you just need the trans as RonD said.
If you have a manual then any Ranger manual for a 2.9 or 4.0 will work up to 2011 as long as it matches 2wd or 4x4
gaz
649
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Sounds like the 89 in question has an A4LD but it needs to be replaced.
lil_Blue_Ford
6,091
Butler, PA, USSA
4.9L
That’s kinda what I got out of it but figured I’d try to make sure everybody was on the same page
forddude92
marshall texas
ford Ranger
yep. 89 with a4ld just needed to know what all i can yank one out of. i appreciate everyones help
forddude92
marshall texas
ford Ranger
but one person said 89 thru 94 and other person said thru 2011. is that for getting one from
Ranger or Explorer too?
lil_Blue_Ford
6,091
Butler, PA, USSA
4.9L
Through 94, Ranger or Explorer. Technically 95-2011 will fit, but you would have to adapt the electrical controls because they are not A4LD but based on the A4LD if that makes sense.
