- Aug 29, 2008
- 1,091
- Nevada
- Ford
- Engine Type
- V8
- Engine Size
- 5.0,4.0
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- 6”
- Tire Size
- 35
Thanks guys!
Do you have a Mity-Vac? I found that the best way for getting the final bits of trapped air out was to make a fitting from a reservoir cap so that you can put the system under vacuum. Then lots of stabs at the clutch pedal. I think I documented it in here - search under my ID.Straightened out the clutch MS and tapped it for the second time. Put it back in and the clutch works but is still a little spongy.
More back on-topic, have you considered running a PCM from a manual Ranger? I'm assuming the pins are mostly all the same, but without the ones related to the automatic trans, and so you wouldn't get error codes related to that.
