- Aug 29, 2008
- 635
- Squaw Valley, Ca
- Ford
- Engine Type
- V8
- Engine Size
- 302
- Total Lift
- 6”
- Tire Size
- 35
I bought this truck about 6 months ago. The original owner had started the 4.0 swap. I was kinda leery about it and I hope the engine is as sound as he claimed. But here’s the basics. The truck is an early 89 that had a 2.9 and a manual trans (FM-146). The motor, dash and majority of the wiring harness is from a 91 Explorer with an auto trans. I’m not sure what model trans. So far it looks like most everything was plug and play except for:
fuel lines
tail lights
reverse lights
cab light
Neutral safety switch wiring.
The fuel lines:
The original owner swapped the explorer’s fuel lines from the engine to the furl filter, into the ranger.
Neutral safety switch:
I had to figure this one out. The transmission harness has two plugs on it at each end. The neutral safety switch has two green wires coming out of it that turn to a white with black and a black with white after about 8”, at a plug. The white with black ran to a black plug while the black with white ran to a grey plug. I had to re-pin both wires, the black wire went up one hole while the white with black, I moved to the grey plug, next to the black with white. This now allows the ignition to crank the starter.
I haven’t started dealing with the tai lights, reverse lights or cab light yet.
fuel lines
tail lights
reverse lights
cab light
The fuel lines:
