89 Bronco II/ 85 Ranger project
Pix3L8
40
Connecticut
Bronco ii
2.9L
Hey guys I have a 89 Bronco 2 and an 85 ranger, I have some questions about swapping the transmissions. The Bronco has the automatic A4LD with an electric transfer case, the truck has a Mitsubishi 5 speed and a Manual t-Case. the truck has the 2.8l and the bronco has the 2.9l. My question is, is it possible to put the trucks manual transmission and Manual t case in the bronco, will it bolt right up? has anyone done this? And my other question question is, will my driveshaft from the automatic work with the manual, i have a 6" lift and a dana/spicer 32" driveshaft, i dont want to drive it with the slip yolk maxed out. Finally can i just swap the tranny and t case, put in the trucks clutch and be all set or is their major wiring and fab work needed to put the Manual trans in the bronco??
any wisdom on this would be much appreciated, thanks
wildbill23c
503
Southwestern Idaho
215/70-R14
You would need the clutch pedal and related items to put in the automatic vehicle, not sure if the transmission will bolt right up, but with enough money you can put any engine/transmission in any vehicle. Personally I'm not a fan of the A4LD and I don't trust it at all, I believe the manual tranny will bolt in though.
Pix3L8
40
Connecticut
Bronco ii
2.9L
thanks for the info
