89 Bronco 2, 3k +rpm’s when started cold, no vacuum leaks I can find, I replaced the tps , the IAC and the fuel pressure regulator
Shawn66
Law Enforcement
Texarkana, Texas
Ford, Bronco II
2.9l V6
3inch
15 inch
Live Free
This truck has me stumped, I can find no air leaks the only thing I can think of is that the vac lines are not where they are supposed to be and it’s causing the fast idle, any advice would be great.
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
If you had a vaccum leak that big it would be pretty obvious.
89 has no EGR so thats not it.
You sure the throttle isnt sticking? Does the idle come down when warm?
Your new IAC may be bad even.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
How does it run otherwise?
Does it settle down to normal idle speeds when warmed up?
How long does it take to settle down?
Shawn66
Law Enforcement
Texarkana, Texas
Ford, Bronco II
2.9l V6
3inch
15 inch
Live Free
The idle will not settle at all I am afraid to let it run very long like that, I don’t want to blow the rings
Shawn66
Law Enforcement
Texarkana, Texas
Ford, Bronco II
2.9l V6
3inch
15 inch
Live Free
When I got it I had not heard it run at all it had no gas tank and no battery, once I got both connected it did not take long to get it to start and this is what happened, I have a Haynes manual but it does not show me where the vacuum lines go so I can’t verify if they are all routed correctly
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
Is the vacuum hose routing diagram still on the core support? Generally though as long as the vacuum line is hooked to something it shouldnt run that high.
You dont have a stuck PCV valve do you?
Shawn66
Law Enforcement
Texarkana, Texas
Ford, Bronco II
2.9l V6
3inch
15 inch
Live Free
I replaced the PCV valve and it helped a small amount but still the idle is crazy high, I pulled the intake and found cracks in 2 places, both of the rear bolts closest to the fire wall that had been repaired with rtv , I am going to get another intake in the next day or so from the salvage yard, I am honestly at a loss if this does not fix the issue, the only thing I have not yet replaced is the O2 sensor if the combination of replacing all of this does not work I think I am just going to cut my losses and sell it there is no sense throwing money at it, I hate to say that because I have put so much into it so far, I have painted it, redid the seats the headliner and new carpet and for this to throw me like this truly saddens me.
rusty ol ranger
2.9 Mafia-Don
7,491
Michigan
177 CID
That cracked intake could for sure be the issue. If not ill be surprised.
Shawn66
Law Enforcement
Texarkana, Texas
Ford, Bronco II
2.9l V6
3inch
15 inch
Live Free
Shawn66
Law Enforcement
Texarkana, Texas
Ford, Bronco II
2.9l V6
3inch
15 inch
Live Free
Well it took me a while but I figured everything out, the manifold was cracked In-N-Out 2 but 4 places and the big part is the lower intake only had the back 2 bolts in it, not only did that make it run with no power and high rpms but it blew the plenum and the head gaskets, I was foolish for not checking them when I replaced the upper intake but I could not imagine they would not be there, so now I am rebuilding the entire engine which I should have done to begin with.
