88 2.9l
Craig, co.
2.9
ok so long time no see, i got this 88 in august and cracked the heads, three small ones on the pass. side, one big one on the drivers side, first off, im looking for improved ones, next is, im rebuilding it, and a snow storm blew snow down cyl. 3, 6, (cover blew off) so can i clean them with some parts cleaner, and then hone them, and then before putting the new heads on, put some oil in each cyl?
fyre82
Firefighter
6
Lake Almanor, Ca.
2.9/4.0
9" on the 2000, 6" on the '88
265/75/16, 31x10.50x15
The memories of a man in his old age are the deeds of a man in his prime
You can clean them up if needed. Unles you are going to tear it all the way down a hone might not be needed.
I cleaned one up with a drill spun wire brush and some cleaning solvent,
runs fine and doesn't use oil that I can tell. Otherwise just buff it up a bit and let it go.
Craig, co.
2.9
well i am doing the entire engine rebuil so i was just seeing what was the best thing to do as far as snow in the cylinders...
