'88 2.9 not running
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
Ranger: 2.9; BroncoII: 4.0
I recently bought an '88 Ranger. It was running good when I bought it. I drove down to the gas station to air up the tires and when I tried to start it it wouldn't start.
I got it home and was looking at it and figured out that the coil wasn't getting grounded. So I switched the TFI Module for one that I had on an extra engine. When I put it on it started and ran. I shut it off to get everything put back together. When I tried to start it again it wouldn't start. So I called my parts guy to order a new Module and he said that the pickup coil might be bad and causing the TFI module to go bad. So I ordered a new P. Coil and TFI module. Before I got the distributor taken apart, I just put the distributor from my other engine in and tried it. it didn't work. Now I got the distributor apart and will try putting the new coil in.
Does anyone have any ideas?
Thanks
RobbieD
2.9l Mafia
3,803
Georgia
I'd go over the wiring around and between those parts, with a fine-tooth comb, looking for corroded terminals, non-seating connectors, and frayed or open spots on the wires themselves.
89RanBrII
33
Newcastle, Wyoming
Ranger & BrII
Update: I put the new pickup coil in and it still is not getting a spark at the distributor. I did find two wires that were worn a little and fixed them. I found that the original TFI module is bad, the one from my spare engine is good, and I don't know about the new one. Edit: The new one isn't working. (I tested them in my working '89.)
Could the computer be bad?
{This is starting to drive me crazy}
rusty ol ranger
2.9 Mafia-Don
8,056
Michigan
177 CID
Im not 100% sure....but i think the ECM grounds the coil to fire it.
So yes....its possible
Cees Klumper
140
De Luz, CA (near Camp Pendleton)
Bronco II XLT
Capacitors in the ECU leak and go bad, causing no-start. It's documented on this site if you do a search. If you open up the ECU you can see whether either of the blue little capacitors are leaking/bulging. You can solder in new ones that cost next to nothing and that would solve that issue - if that is in fact the issue.
TexasDuck66
July Truck of The Month
