- Oct 24, 2012
- 158
- Middle Tennessee
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- 4WD
- Total Lift
- 1.5" Front + 4" Rear
- Tire Size
- 245-70-R16
Cylinder 1.......................... 135
Cylinder 2.......................... 135
Cylinder 3.......................... 80 (115 after some oil in the cylinder)
Cylinder 3.......................... 140
This was done with the engine completely cold.
I've also noticed a significant amount of air bubbles at the radiator when the truck is running and the heater core keeps breaking loose. Sounds like compression leaking into a cooling jacket to me.
Just wanted to get some thoughts from the experts. Is a head gasket likely to do any good? Or is the whole thing weak enough that it wouldn't be worth it? Junkyard engine maybe? Although I've noticed an '02 FX4 on Craigslist not far from here. Only listed at $3500. (Too much for me but supposedly a good deal) Link for anyone else interested: http://clarksville.craigslist.org/cto/3412382313.html
A little background: I've been fighting this things low power since I got it. I had an '86 4x4 before so I know about where it should be. (It's fairly close.) I reworked the entire set of fuel lines (main pressure line was almost in two at the tank), changed the front fuel pump from one of those aftermarket universal deals to the correct one from the junkyard, replaced spark plugs, and the fuel pressure regulator to get it to idle correctly. Now this...
Thanks for any ideas you can offer.
