MikeW
- Jan 1, 2017
- Reaction score
- 0
- Make / Model
- Ford
- Manual
1st off I hope this is in the right forum...
OK...I know what the dpfe is and what it does. I'm not looking for technical advice or diagnosis, I've done all that. Specifically what I need is a replacement.
That being said on to my problem. My stock dpfe sensor has 2 parts to it with 2 electrical connectors (1 for each side) there is a small (approximately 1.5") piece of vacuum tube that runs between them, and then the 2 ports on the left solenoid.
This particular setup seems to have vanished from existence for purchase unless I'm willing to spend 200.00+ and wait 6 months to get the part... I'm not. Sooo on to my question.
Since all the dpfe sensors do the same thing in reference to their function and any dpfe (should) work.... what are my options as far as replacement? The SMP vs44 (or equivalent) is what is in there now. (the above configuration) Since it is no longer available and the other dpfe sensors (which only have 1 wiring connector and 2 nipples) are readily available... what can I do about that 2nd solenoid, wiring harness, and crossover tube?
I have been staring at this book, harness, configuration and scouring the internet for over a month now looking for a solution and I'm about at my wits end!
I see them occasionally in the bone yard but these things are 30 years old and can't possibly be in much better condition than mine.
I just replaced my egr valve (bad diaphragm) and map sensor but it's going to be all for not if this danged dpfe system can't be.... retooled... to a more up to date (available) part.
Anyone else had any luck with this? TIA!
Mike
(PS I have 0 interest in deleting the egr system, but thanks for the suggestion)
1987 Ford Ranger xlt 2.3 efi 5sp rwd vin A
Mike
