SHE RUNS! I reset the timing, pulled #1 piston to TDC on compression stoke, pulled and reset distributor into the cam gear. Pointed the rotor at spark plug #1. Little starting fluid and truck is running again.
Yesterday morning I drained the milky oil and filled with fresh oil and changed the filter. I also pulled the plugs and dripped a small amount of oil in cylinders for extra protection.
There is a ton of white smoke flowing out of the exhaust. I assume it’s because of the oil put in the plug holes.. hope it’s nothing worse.
I drained the oil and filled with fresh 5w-30, still a hint of chocolate mile but much better. Smoke is getting less as the truck runs but it WILL NOT accelerate. Just bogs down until I advance timing by turning the distributor.
