87 B2 Wiring Harness replacement
TastierCash
Mississippi
Ford Bronco II
So I’ve decided to pick up where i left off on fixing up my old b2 and I've ran into a few problems, one of which being the engine bay wiring harness. The old wiring harness has a bunch of connectors that either have tabs broken off, broken wire, or part of the socket itself has broken and I was wondering if anyone knew of a company that makes replacement harnesses for B2’s? Any help or advice is appreciated.
1984RESTOMOD
160
midwest
ford ranger
302
3" BODY LIFT
33"
Watching this thread because I'm in a similar situation with my NA V8 swap '84 and have little idea where to start being a novice.
SenorNoob
TRS 25th Anniversary
1,356
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Most of the connectors are available as repair items. That's about as good as it gets.
TastierCash
Mississippi
Ford Bronco II
I was hoping to avoid having to splice any wires cause im not very good at it, especially when it comes to soldering. On another note, if someone is able to inform me, how can i tell if i need to replace my cylinder heads after the truck sat for about 20ish years? (i already have one of the heads off and the gaskets were toast)
Cees Klumper
167
De Luz, CA (near Camp Pendleton)
Bronco II XLT
only lift is from the oversized tires
You could:
- look for a used good harness at a salvage yard, or try Ebay
- have the heads checked by a machine shop
RaceRanger97
December Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
