86 ranger lift kit with axle swap
Dlillie87
7
Florida
Ford/Ranger
If I put a Dana 44 TTB and an 8.8 under my ranger, would lift kits for my truck still fit, or would I need to look into a custom job?
ericbphoto
Overlander in development
16,509
Wellford, SC
3.0L
6"
Rear should be fine. Front depends on exactly how you installed the D44. But I would expect any custom fab needed to be minimal. Also might depend on which lift kit you're talking about.
Dlillie87
7
Florida
Ford/Ranger
My plan is to attach the dana44 to the original locations and cut the inner passenger axle 1.5-2 inches, based off of the write up on here that looks the easiest. And probably the 4in rough country with new front and rear springs. Hopefully very minimal customization will be needed
ericbphoto
16,509
Wellford, SC
3.0L
6"
Be aware that there is an issue with the Rough Country lift, if I recall correctly. I believe it presents an opportunity for one of the axle beam brackets to hit the differential. Check the tech library here.
Dlillie87
7
Florida
Ford/Ranger
I think I remember seeing something about that from using drop brackets. I'll look more into it
scotts90ranger
4,311
Dayton Oregon
2.3 Turbo
Yeah, that, but a TTB Dana 35 has the same outer U joints as a Dana 44 TTB, the only real gain is wheel bearings which if you keep the tires in tight like they should be isn't a huge problem up to about 35" tires... Some people can't keep shafts in them but I've yet to break one, but I don't have torque, just horsepower...
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
Stay away from that roughy country lift if you’re going to use any TTB other than the Dana 28. The rough country uses a drop plate to lower the stock axle pivot and the plate will smash a hole in your diff when you flex suspension. The skyjacker uses a new longer axle pivot avoiding that disaster.
Image from TRS
Dlillie87
7
Florida
Ford/Ranger
I have the dana28 currently. Definitely swapping that out before I drop the V8 in
Skyjacker is definitely looking like a better option.
