2.0L ('83-'88) 86 Ranger 2.0 Carburetor Options
86Ranger2.0
WV
Hi all,
I just bought an 86 Ranger with the 2.0 engine. Currently it has the stock Motorcraft single barrel carb on it & I was wondering what 2bbl options were out there for this engine? Does the 70s pinto or mustang intake & carb fit the 2.0 engine? I was considering using this https://www.jegs.com/i/Trans-Dapt/969/2125/10002/-1 adapter I saw someone use on a 2.3 engine to convert to the Holley 5200 2bbl. Will that work on the 2.0?
rusty ol ranger
Im a Jeep guy now.
7,403
Michigan
177 CID
I believe a 2.3 manifold will work on a 2.0.
However...dont fall into the trap of over carburation. 122CID doesnt require much CFM
Blmpkn
Toilet enthusiast
6,358
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
How much do you want to spend? A 1 bbl efi carb would add a nice modern touch while keeping the same spirit.
86Ranger2.0
WV
Im looking to replace my worn out carb as cheap as possible. The adapter from jegs arrived today and fits like a glove. I ordered the holley 5200 so we'll see how it mates up.
86Ranger2.0
WV
So I got it all installed & the truck runs fantastic. It all bolted up just fine & all the issues I had from the previous carb are gone. It even has a bit more power & a better sound. Was way easier to tune also but I decided to spray carb cleaner around the base gaskets on the carb & the adapter to intake & they are leaking. Its torqued snug & I used the gaskets that came with the adapter. I might try using some grease on the gaskets or some of that permetex blue gasket dressing thats fuel resistant & see if that seals it up. Otherwise I guess I need thicker better brand gaskets? All surfaces were thoroughly cleaned & tightened down. I also made sure everything fit down flush & flat before tightening.
86Ranger2.0
WV
Blmpkn
Toilet enthusiast
6,358
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
I'd try a fatter gasket before the sillycone, glad to see the new carb has done it's job.
86Ranger2.0
WV
Ill give that a try.
28778
Hi all,
Do u know we're I can get a decent priced carb and I own a 86 ranger 2wd 2.0 I've got a lot of questions man lol I. Trying to get this truck running carb broke after a smoking pump delete and ran some evap hoses together I shouldn't have had a horrible idle and lottery shook the carb apart looking for a easy bolt on or just with the same plate as u used what we're u looking at that u know would bolt on directly. Lol sorry for bombarding u 😂😂😂
Hi all,
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
ebay....fresh units for350-400 bux.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
or questionable :unsure: ....but do it anyway:woot:
Josh B
1,986
Oklahoma
Would an old carb be rebuildable? I have a number of them, but not sure you would even find a kit for one any more. And they haven't really been pampered
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
most of em have stuff available.......just figure out your model number and try to order a kit.
Josh B
1,986
Oklahoma
I'll be happy to set you up with one anytime you want it
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
dont think i would rebuild....just buy one of those critters and go....
