86 Bronco II... G-Unit
fastpakr
2,832
Roanoke, VA
Years and years ago, JC Whitney offered a 35 gallon fuel tank for the Bronco II. I always wanted to see one up close for comparison on how far it hung down.
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That one would probably be half empty with today's prices... to much room for condensation.
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Besides... I'm shooting for 30+ mpg with old rattle trap.
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
So I finally looked under the hood of my 88 for the fuel filter. Got you a pic but I dunno how well you can see it. There’s a hose clamp that holds the filter inside the sort of bubble in the frame and the front fuel line fitting makes a 90* right off the front of the filter. Looking at it, I’m definitely inclined to do something different before I put this thing back together. You can kinda see the end of the filter with the fitting
racsan
4,440
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
The way ford does their fuel filter has always been strange, hose clamp it to a bracket thats bolted to the inside framerail. At least the bracket has studs, 13mm nuts, dont need to have a 2nd wrench. But the ends of the bolts are right in the salt bath. Ive never had them break off, and Ive always anti-seized things up good when I reassemble.
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm having a hard time with that picture. But I just followed fuel line from the injector rail to the spot where the high pressure frame rail pump was. No in-line filter.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Up the frame farther.
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
As many of those as I've changed over the years I'd have to believe if there was an in-line filter I would see it.
I know it seems odd but there is no in-line fuel filter between the high pressure frame mounted fuel pump and the fuel injector fuel rail.
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
Interesting. I will say, even with a stripped engine bay, it was hard for me to get anything approaching a decent picture of it. My choptop and 92 have the standard bolted on bracket back down the frame more. This one is so close to the engine crossmember that the fuel line has to make a 90* immediately out of the filter or it hits the crossmember. Maybe yours wasn’t like that or maybe someone eliminated it? Not really sure what to tell you. It certainly is a hard to see and access spot though. Above the Radius Arm and front driveshaft, behind the coil/shock bucket and engine crossmember by the exhaust...
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Yeah... there is nothing there.
I won't say it wasn't removed... but the plumbing looks original.
I looked for a date code on the door sticker... I couldn't make out the date with a flash light but I will look again in different lighting.
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
It’s been three concussions and a number of years since I stripped and scrapped an 86 and 87 Bronco II that I don’t remember if they had a filter there or not, so maybe it was something that was added in later production first gens.
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Bronco ii Man
43
Southport NC
Ford Bronco ii
2.8 V6
2.8 v6
31x10.50-15
The red look’s good on it! Should make it stand out a bit after you get it installed!
