85 Ranger 302 swap
taco
I need help with finishing up my 302 swap. It started as someone else's project, and my father got it for me as my first car. I thought I figured most of it out but now I need some help finishing it. I have a 92 302 H.O from a T-bird that is swapped to carb. The engine wiring is very pieced together with just random bits and pieces, but that is being sorted through slowly. I am having trouble with three things as of now, and the most important is the fuel delivery problem. It has a holley 780 CFM carb and a holley regulator set to 4 psi and it was running fine with that, but now the gauge is fluttering rapidly and fluctuating between 2 and 15 psi before settling at 0 and the engine dies from no fuel. I thought it could maybe be the diaphragm in the regulator, but I'm stumped with it. I have new fuel pumps set up as how the stock fuel delivery system was set. Once this is figured out I will move onto the other problems which is a stumble while revving the engine, and figuring out a one-wire alternator that will work with my setup. the first distributor was all electric and didn't advance ( it was the stock T-bird distributor) I now have a retro-fitted GM distributor with vacuum and mechanical advance. Any and all help will be greatly appreciated
Thank you, mac
8,370
1985 Ranger should have 7-9psi fuel pump in the tank, and if original engine was fuel injected then high pressure pump on frame rail under drivers seat.
Remove the high pressure pump, it isn't used with carb setup.
What fuel pressure regulator are you using?
1 wire alternator just hooks to battery via a fuse, mega fuse, usually on a power distribution post on the fender, i.e. starter relay.
1 wire alternator shuts off below a certain RPM, and then starts up again above a certain RPM.
very simple setup, but not good if you decide to use under drive pulley on crank, you would need to change pulley on alternator as well
Yes HEI system is best for spark in your setup, also very simple to wire and setup.
Vacuum advance on distributors use regular vacuum or Ported vacuum.
regular vacuum is below throttle plate on carb, Ported is above throttle plate
regular vacuum is high when throttle plate is closed, ported vacuum is low
ported vacuum is high when throttle is open, regular vacuum is low
Most use regular vacuum, but not all, lol.
alwaysFlOoReD
5,088
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
There won't be a high pressure pump. 86 was the first year for EFI.
Sent from my XT1032 using Tapatalk
No members online now.
