Wanted 84 ranger cab mount
1984RESTOMOD
52
midwest
ford ranger
302
2" BODY LIFT
33"
Hey there, looking for front cab mounts for single cab long bed '84 ranger. ive been able to find the rear ones on mill supply but no luck with the fronts.
4x4prepper
216
Atlanta
James Duff has a set of the blue poly, holding up so far, only about three months installed so far, I made my own replacement hardware for them.
1984RESTOMOD
52
midwest
ford ranger
302
2" BODY LIFT
33"
Not seeing them... I'm looking for the bracket itself that mounts to the frame
4x4prepper
216
Atlanta
Okay, misunderstood. Last time I fixed them on a B2, I used thick alloy grade 8 washers, about 3" wide and attached them to the rusted out bracket. Since the front body mount uses these:
and these:
which are a pain to duplicate, which I have done to make a custom mount, I would make my own steel frame brackets and just use a regular generic body mount from Summit Racing that takes a 1/2" bolt.
4x4 x 1/8 (11 gauge?) would be enough and when cutting the upside down L shape bracket, do it at an angle so it looks like a triangle from the side.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Just bumping this to the top for the OP...
Still looking for a set of front cab mount brackets; they are attached to the frame with 4 rivets just above the radius arm bracket. Not able to find online so if anyone knows a part number or has a parts truck please leave a comment.
