neinnein_nein
- Aug 5, 2017
- 30
- new york
- ford ranger
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- soon-to-fire up 2.3 turbo lima
- 2WD / 4WD
- 2WD
- Total Lift
- 3!!
Hey guys. I’ve been slowly rebuilding my 1984 2.0L ranger for the past two years, all the starting components are new, plugs starter relays distributor, cables etc, and I dropped in a new clean fuel tank, filler hose, new sending unit, fuel filter once a year and I rebuilt the carb twice (last time was two months ago).
It runs well and usually starts right up when you pump the gas before turning the key, isles smooth except for the occasional small stutter (but really rare). Now two months after the last carb rebuilt it’s starting to have occasional trouble starting properly. It starts, does out, and then it’ll crank forever without engaging no matter what you do and how much gas you pump into it.
The last time I rebuilt the carb, that’s basically what it did until it didn’t start at all, and the problem was there were literally deposits of little rocks inside the carb, which were cleaned out.
Something is telling me it’s that again and that it’s coming from crap that accumulated in the fuel lines. Is that a possibility you think?
Was I stupid to change most of the fuel system but overlook the lines or can it be something else very obvious?
