For Sale 83-92 Power Window/lock "conversion kit"
Junk Collector
Forum Moderator
567
Rapid City SD
I converted my '88 to crank windows and manual locks and would like to offer the parts I removed to someone who either needs repair parts or just wants to convert from manual to power - anyway this is what the "kit" includes:
- both regulators
- two good windows motors - these are aftermarket, fairly new pieces, replaced by the previous owner of the truck
- two good lock actuators, OEM Ford parts
- buttons and trim (blue) for both doors, all functional, some wear on the buttons themselves
- both door wiring harnesses - these will need new wire loom, it crumbled off when I pulled these out of the fenders.
- "center" wiring harness - this is the main piece that crosses over the radiator from fender to fender and normally contains the headlight wiring as well but that has been removed and ONLY the PW/PL wires are there. One side of this runs to the starter solenoid which makes the power lock relays (included with this harness) hot at all times, and one wire on the other side that can be connected to ignition hot or hot at all times for window motor power. Several pins on this were replaced because of corrosion but I tested it pretty thoroughly and it works great.
This is a pretty easy conversion, just run the wires, hook up two grounds, two hots, mount the regulators, motors, lock actuators and modify your door panels for buttons as opposed to a window crank handle and you're done.
$75 shipped to your door
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
gaz
Active member
29
Wa, Bremerton 98310
2.9l
Hello,
I am interested. I swapped to cranks but can't keep those quarter windows secure.
Please let me know if you still have the setup.
Kevin
Junk Collector
Forum Moderator
567
Rapid City SD
Hello,
Kevin
Yep, still have it. PM me and we'll work out the details.
gaz
Active member
29
Wa, Bremerton 98310
2.9l
One day can sometimes change the world. I will have to get back to you in May; yesterday's unexpected expenses set me back.
I don't expect you to hold, so I will contact you next month.
Junk Collector
Forum Moderator
567
Rapid City SD
Bump... This is still available
markinms
MS
5.0L EFI
Duty, Honor, Country
I'll take em! Let me know what we (I) need to do. Thanks!
Mark
markinms
MS
5.0L EFI
