Installed new spark plugs, new air filter and recreated a clamp fastener for it since it was loose one corner, put on new windshield wipers (!), refastened an unoccupied bolt hole in the right radius arm bracket to frame, picked up some RVT sealer stuff and correctly spec’d gear oil for the rear differential which will be redone soon, pulled some OBD codes after a test drive, took off and cleaned out the IAC w throttle body cleaner and tested and confirmed its solenoid action with key on engine off...
Went and picked up both a Coolant Temp Sensor and an O2 sensor. I got a code about the coolant sensor and also have discovered that high idle can be caused by a faulty coolant temp sensor. Will install that in morning. I’m very hesitant to install the O2 sensor though since I’m not confident that the code readout for the O2 sensor really means the sensor is bad but can mean lots of other things. Plus I know it’s much more of a pain to install. I may return it but will hold into it for a bit.
Every step I take the engine gets better and smoother. The ticking still occurs and mostly disappears after reaching operating temp. (I will be getting aggressive soon and doing some Rislone and more Seafoam rounds.) The power is getting nice, especially considering the tires. But the one thing that’s still obvious is that the exhaust is not healthy for humans. The engine idles around 1100 in park, but sounds smooth. But it’s too high, almost like the truck is constantly being accelerated a little. This of course only contributes to the exhaust being prevalent. There isn’t any smoke after it’s warmed up. Sometimes very little during warmup too. So I’m getting close, I just need to get the engine toned down so to speak. And also keep correcting all the small issues that lead to improper balance.
All six old spark plugs look the same.. they’re quite old looking, with a good bit of rust color on outsides. The plug tips are all dry brown. The threads are all a little oily. See attached pic. I’m almost positive the replacement with new ones (all measured for gap) made a nice improvement. I believe there has been less random stuttering / loping since the change.
So my priority is bringing down the idle during park and cleaning up the mixture and exhaust. In drive the idle drops down nicely. But I know in park it should be lower than it is.
On Tuesday I’m dropping it off at a trusted shop to take a look at the rusted bolt in flange holding Y pipe to right manifold. It’s the spot that has a small exhaust leak due to not being fastened fully. The engine is still pretty gnarly when giving any throttle. When cruising with the engine idling, it sounds very smooth. When giving it throttle, it gets raspy during revs. I’m sure some of this is the small hole. I know how loud an exhaust is and the tiniest hole will make noise.
But I’m not convinced this hole is all of the noxious exhaust getting out from the truck. I think some of it is engine performance which I need to keep tweaking.
My fingers are still crossed that something major isn’t wrong with the guts of the motor. I haven’t had any evidence of anything like major cylinder issues but I’m still learning this stuff.
Drove it at 50mph recently and enjoyed it.
