Wanted 80's Driver side seat rails
sexybluelady
16
springfield, ma
ford, mitsu, do
2.9
Need some seat rails from a 80's Ranger or BII or bronco. Or whatever else will work for my 88 Ranger standard cab.
JoshT
2,829
Macon/Fort Valley, GA
Got none for you, could actually use a set myself, but thought some info might help.
For a 1988 standard cab Ranger, you need seat rails from an 1983-1992 standard cab Ranger. Up to 1997 may fit, but through 1992 for sure. They have to be standard cab, not extended cab or BII.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
5,565
woodhaven mi
FORD mostly
BIGGER
sawzall?
probably easier to make some out of strap.
Rick W
Lil Big Rig
Truck of Month
5,535
Atlanta
Ranger XLT x2
4.0 & 2.9
97 stock, 3” on 87
N/A
Never put off ‘til tomorrow what you can put off indefinitely
When I bought my 93 extended cab donor for the wheels for the Road Ranger, I ended up using the OEM seats in my 87 short cab. The front bolts to the floor lined up, but I think I had to drill a hole through the floor and use flat washers for the back.
Ditto. Putting it under the seat, I think the holes almost lined up, but all I had to drill was two new ones.
My memory is a little fuzzy, but It was no trouble at all.
hope it helps
sexybluelady
16
springfield, ma
ford, mitsu, do
2.9
Thank you all. I just welded in a new floor so I will have to drill in new bolt holes for the rails.
JoshT
2,829
I was going to remind Bobby that not everyone is the fabricator that he is.
Then I took a look at your sig links and decided, nah, she's probably got it.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
5,565
woodhaven mi
FORD mostly
BIGGER
sawzall?
yeah.....she can definitely rebuild the seat mounts.
sexybluelady
16
springfield, ma
ford, mitsu, do
2.9
Thanks for checking out my pages. Yea I'm a master fabricator by trade title. I could make some brackets with sliding rails, but it comes down to a time issue for me. I would 100% rather buy some stock brackets/rails than try to find time to make some.
Rick W
October Truck of The Month
25th Anniversary Merch
