8.8 interchangeable?
1991 Blue danger ranger
20
Alberta, Canada
235/75R15
I’m after a limited slip rear axle for my Ranger (1991 with an 8.8, 3.55) and I found one on Facebook marketplace out of a bronco/f series that has the same gears and is an 8.8. Could I use this no problems? Or would it at least be easy to convert? TIA.
rusty ol ranger
2.9 Mafia-Don
8,553
Michigan
177 CID
Be way to wide.
20
Alberta, Canada
235/75R15
Do you know how much wider? I don’t mind more offset from the wheels, just not excessively
rusty ol ranger
2.9 Mafia-Don
8,553
Michigan
177 CID
SHEESH. Never mind then. I also just remembered that they use a 5.5 instead of 4.5 bolt pattern so I was pretty much dreaming anyway
You might try www.car-part.com to find a limited slip with the ratio you want.
Ranger/Bseries are direct swaps, explorer 8.8'a will work if you reweld the spring perch on top of the axle
Rick W
October Truck of The Month
25th Anniversary Merch
