8.8 in a 7.8 case??
87dytnajeff
Does anyone know if it is possible to take the innards from an 8.8 axle and put them in a 7.8 housing??
i know i'd have to change the diff cover, is there anything else i need to do IF this is possible??:icon_confused:
Junk Collector
Truck of Month
4,789
Rapid City SD
You just have to grind the inside of the housing so the ring gear will fit.
stegomon
20
auburn/minot maine
fords and only
mat i ask why you would do that?
A 7.8" housing? Are you talking about a 7.5, or are you using some screwy GM axle?
Either way, I wouldn't try it.
