I have the housing sitting under the truck right now, I had to take a break from fabbing and get all of the TTB stuff out of the way.
I found some caliper brackets and spindles for my knuckles. Im going to build a jig so that I can machine my flat tops on my mill and build some arms.
I havent seen the Extreme show where he built the 14b front , but ever since I started this axle I have heard about it, and Im interested to see it. I just thought it would be different to build an 8.8 front, and with the abundance of parts out there I figured it could be done fairly cheaply. The shaft diameter of a 31 spline 8.8 is the same as a 30 spline D44, so all Ill have to do is have D44 shafts splined to match the 8.8.
I dont have to have reverse cut gears, because it is a low pinion housing. Normally a low pinion housing would be weaker because the pinion would be "pulling" away from the ring gear instead of pushing against it like it would be in a high pinion setup, this is what contributes to the 10-20% disadvantage. however, I dont think it will be any weaker than an HP44 because the tooth contact is so much greater with 8.8 gears over a D44, it looks to me like there could be up to 50% more contact on the tooth surface itself.
Im gonna bust loose on my build here very soon, i wanna have this thing driveable this summer. Ill keep you posted.
