74 d44 on an 84 ranger
1989
kalama wa
2.8
I know i can find it somewhere in the forum but I wanted a little more of an opinion on the axle itself and also if it would work properly with my ranger the axle is out of a 74 wagoner it's a complete axle with 354 gears
4x4junkie
532
So. Calif (SFV)
2.9L V6
35x12.50R15
'74 Wagoneer has the diff on the wrong side (passenger side). You would need an '80 or newer Waggy axle.
bobbywalter
TRS Technical Staff
3,897
woodhaven mi
FORD mostly
BIGGER
sawzall?
if you swap in a big engine the side of the tcase drop is easier.
nice 5.3 with a nv3550 and a chevy 208 case....probably use the waggy case if you use a ford trans easy enough.
1989
kalama wa
2.8
Ok so I didn't get the wagoner axle I decided on a d44 from an f250 with leaf over and now I need to decide on a set of leaf springs but I want something that will give me at least 5 inches of lift 4 would be ok too any that you would recomend ?
bobbywalter
TRS Technical Staff
3,897
woodhaven mi
FORD mostly
BIGGER
sawzall?
look up nmb2's build
he has a cool setup that you can incorporate degree shims with if you want to go rear shackle.
i am running chevy 54's currently. bout 5 inches of lift on a front shackle setup.
