• Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' the posts that you read.
7.5 drive pinion removal
kimcrwbr1
Well-known member
37
maplevalley WA
2.8l
I am trying to remove the drive pinion out of the axle housing and the pinion is not budging out of the front bearing. I got it to move about 1/8 an inch and now it is froze solid. Short of taking a 10lb sledge to it is there a trick to popping it out I am at my wits end any help will be greatly appreciated.
Rock Auto 5% Discount Code: 4FF3E9EEA14805 Expires: October 1st, 2020
kryptonitecb
New member
17
Fort Worth, TX
Mine fell out once the spindle nut came off. Baby beater is always an option.
Sent from the road while ignoring traffic
kimcrwbr1
Well-known member
37
maplevalley WA
2.8l
Well it got me bleeding first I tried the large hard mallot then graduated to the 3lb sledge and a block of hard wood. I am now metal to metal and the threads are extra extra fine. I tried to torch the bearing also to nodda. WTF it should slide right out I`m afraid if I hit it any harder I will need a different housing. I already bought a used trac-loc 3.73 set once I get the drive pinion out it should fly together if I dont F up the housing.
kimcrwbr1
Well-known member
37
maplevalley WA
2.8l
Power steering fluid a torch and a big hammer the outer race was rusted to the drive pinion. I`m guessing when I first got the truck 9 years ago I topped off the differential fluid after it had sit for a few years low on oil, moisture must have migrated in just enough to get the inner race wet everything else looked fine. I hope I didnt damage the housing it was dark and starting to get chilly out.
