7.3 boost?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
How much boost does a stock 03 7.3 make? Any ideas? Working on the f350... I'm completely new to diesels. Brought up manifold pressure on the scanner and its hitting 35psi. That cant be right can it?
rusty ol ranger
Im a Jeep guy now.
7,415
Michigan
177 CID
For some reason 20 psi is sticking in my head, but dont quote me.
35 seems high. My cummins ISX15 pulls 40.
Checked google...seem 17-20 is normal. 30 is "extreme", so im guessing at 35 youre getting pretty close to an explosion worthy of a 6.0.
I can't find an actual stated maximum spec, but in the boost testing procedure the say the gauge you use only needs to go to 30 PSI, and that 16 is the minimum.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Hmmmmm..... gotta be the wrong PID or just off all together. On graphing you can watch the rpm rise and half a second later the pressure. Peaks on map sensor at 35psi. Still learning both diesel and forscan though.
snoranger
Professional money waster
ASE Certified Tech
13,613
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Is that actual intake pressure? (Baro + boost) I've seen it measured that way on some of the bigger International trucks.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
put a gauge on it.
