5r55e missing the downshift
Maxinstl
St. Louis
Ford ranger 4.0
Sometimes when getting on the highway coming home from work, I accelerate to get onto the highway, then merge. After merging, I attempt to accelerate again, causing my trans to attempt to downshift, but it misses a gear (I think) and revs out with no power to the wheels. I think it's between gears, but I'm not sure. It catches when the revs get back to about 2.5k, not violently, almost like a normal shift. It has happened a few times now, all in this situation. I think it's the 4 to 3 downshift, but I'm not positive on that...
Is a shift solenoid going bad? It shifts properly 99% of the time when merging, just every once in a while it gives me the problem, never on the upshift.
alwaysFlOoReD
5,086
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Have you checked the fluid?
That's all I got.
Maxinstl
St. Louis
Ford ranger 4.0
That's all I got.
It's just a little high, but it's been that way for 20k miles. This is a newer issue. Actually it only started when I started this new job and going home this way...
Thanks for the suggestion though! I appreciate the reply.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Turn the od off until your on the highway. Whats happening is the trans is shifting into overdrive, then immediately needing to unlock the converter, and downshift two gears which causes a massive lag of nothing. It's happened to me plenty of times in the same scenario you describe. If you leave the overdrive off until you're ready to cruise it wont happen. It's a computer controlled transmission, and computers are dumb.
Maxinstl
St. Louis
Ford ranger 4.0
This must be it, it makes a lot more sense. I'd buy you a beer if I could.
Uncle Gump
Token Old Guy
13,452
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
If that doesn't work... try another new job?
Kidding of course.
I think dirtman hit it right. I have a funky "on ramp" to the tollway that pretty much does the same thing you describe. Except the no power to the wheels thing. Mine will kick out the TC and downshift... pull until it's ready for the next gear.
Just try to cancel OD... and see what you get.
8thTon
--- Banned ---
806
Pennsylvania
My world is filled with stuff that needs to be fixed
Clean the MAFS and change the airfilter. It makes a huge difference in how it downshifts, as it needs to know airflow to determine load.
Maxinstl
St. Louis
Ford ranger 4.0
Kidding of course.
I knew with the way I phrased it it was only a matter of time before a smarta$$ made that comment... ?????
I have a base model, so no tc for me.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
TC = torque converter. You definitely have one lol. The Torque converter has a clutch in it that locks after the transmission shifts into overdrive so there is no power or rpm loss between the engine and transmission while cruising at highway speeds. It disengages as soon as the transmission goes to downshift.
Maxinstl
St. Louis
Ford ranger 4.0
Oh I thought he meant traction control.
Doesn't it lock depending on rpm? So when it hits like 3500 its locked in any gear?
Uncle Gump
Token Old Guy
13,452
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Torque Converter (TC) lock up is more related to load and vehicle speed then engine RPM.
Maxinstl
St. Louis
Ford ranger 4.0
I did not know that
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
The 5r will only lock the converter in overdrive unless overdrive is off then it will only lock in 3rd (or 4th depending on how you wanna count the gears, the 5r55e is technically only a 3 speed with overdrive not a 5 speed). But it does depend on the load as well, as soon as you take your foot off the gas the torque converter clutch disengages and only re engages when certain criteria are met. You also have a coast clutch too lol but that's only functional with overdrive off for engine braking while towing.
I always drive with od off unless on the highway. For me at least, it just makes it drive nicer below 50mph or so.
