$50 vs. $5 air filter
McFuzzie
Vancouver, WA
4.0 L V6
Just a quick question. I was looking through different air filters online and saw a K&N air filter that was $50. It wasn't a special cone air filter or anything, just a regular "high flow" rectangle one. Is there a huge difference between that one and the $5 one I buy at my local parts store? I honestly can't see how the K&N filter can be that much better. I'm not running a aftermarket intake system or anything.
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
^^x2
<< anti k&n
simple answer, k&n flows better than paper when perfectly clean, flows the SAME as paper before it is visably dirty, and filters the same as paper(brand new paper) when it is nearly black, so if you want dust in your motor, it will flow more, if you want it to filter as good as a paper, you starve your motor of oxygen... save your money buy paper, OR
put an aftermarket or custom filter system on, which will give you more surface area for the filter... ie instead of a 1'x1' filter, put a new airbox on that has a filter that's 2'x1'...
Big Jim M
30
Austin
Times three
SAVE your money! K&N is all hype!
Big JIm:hottubfun::wub:
Nhaz
4
The Great White North, Ottawa, Canada
1998 and a few
Ranger+Ranger+E
4.0 3.0
5 goes in to 50 how many times?
in other words. it will take 10 YEARS of buying a OEM filter to pay for 1 K&N which actually isnt as good.
No brainer in my opinion
McFuzzie
Vancouver, WA
4.0 L V6
I figured it was all hype.
But I never thought of putting a bigger box in, I might look into that. Thanks mates :icon_thumby:
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
How many miles a year do you drive to only buy a new filter once a year?
fastpakr
2,832
Roanoke, VA
How often do you replace your air filter? 12 to 15k miles is pretty standard.
mjonesjr
Firefighter
13
Salem, IN
In my Ranger I change it 1 time a year because I only drive it about 5,000 miles a year. In my wife's Jeep, it gets changed twice a year; every 6,000 miles.
The early year change is more of a precaution. However, the late summer or early fall change is almost a must since the farmers in the area are harvesting their crops creating a lot of dust in the area where we live.
tonyjklh
FORD
4.0L v6
dont get a K&N filter. i had it before and never noticed a difference. standard filters also protect better in my opinion, and i would always go with the best protection if you do any kind of mudding or wheeling., ive had mud sucked up into my airbox so many times and never had any pass the filter. i end up changing my filter at least once a month because of mud. cant wait till i get a snorkel put in.:icon_thumby:
Nhaz
4
1998 and a few
Ranger+Ranger+E
4.0 3.0
I put 40,000 on my truck last year. I had 4 oil changes and 2 air filters. both times I changed the air filter it didnt really need it.
most people dont put 40,000 on their trucks in a year.
--weezl--
Law Enforcement
182
hell
you put 40 000 km on your truck and only did 4 oil changes? i've put 20 000 on mine since september, and done 4-5 oil changes, and 3 air filters (mud contamination) going to be looking into one of those water socks
fastpakr
2,832
Roanoke, VA
With good oil/filters and occasional sampling, there's no reason you can't go 10k on oil changes.
Big Jim M
30
Austin
Just for shits and grins
I'll post my milage on filters. First off I have owned several Bobcats. I run them in EXTREME conditions. After a week or so I pull the air filter and BEAT it against a tire to throw most of the crap out of it. Then I drive it again for a week or so till the thing begins to smoke from lack of air.. I then BEAT the hell out of it again! I do this for a few months till I need to change the oil.. Then and ONLY then I install a new filter.
Now for my on the road vehicles.. Street driven vehicles get 125/150,000 miles on a air filter.. NO PROBLEMS!
My off road vehicles get the filter examined regularly. Many times I shake the dirt/dust out of them and reinstall em. As long as they are passing the air needed to run the vehicle they are still doing their job. I have never seen a reason to needlessly install a new filter.
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Does the K&N filter flow more air than a similarly sized paper element? Yep, it does.
Is that "extra" flow going to make more power? Nope.
Where the faulty logic comes in is the idea that the factory would build a system where the filter wasn't big enough to supply the engine.
On Most Ranger engines the air filter isn't materially smaller than the filters used on 7.5liter (460) powered F-series trucks.
the difference between my 1988-94 ranger filter and the fileter used on the F450 I used to have is that the F450 filter was about 1" wider.
AD
BlackBII
Ranger Custom
Truck of Month
982
UT
