BobbyLeeMFFR
- Jun 24, 2024
- 0
- 99180
- Ford Ranger
I am wondering if a 2001 5 speed manual 4x4 4.0L will bolt into my 1990 2.9L 4x4 manual
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
so I got the transmission in and working properly but now its not getting enough fuel pressure from what I have seen on here even tho the fuel pump is working its not producing enough fuel pressure and I am wondering if instead of pulling the pump out of the fuel tank which I really dont want to do can I add a high pressure pump like the older ones have?Yes, the transmission will bolt up but make sure it's the same length, a 2.9L probably had a TK transmission instead of a M5OD like the 4.0L and in the early days there were several different lengths which affects driveline length and if you have a TK transmission and a manual transfer case the linkage is different than an M5OD not to mention around that timeframe they took the T case shifter boss off the side of the extension housing...
