5 speed grinds unless I shift like a grandma.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
I really gotta baby my shifts to keep it from grinding gears. I suspect worn synchros, am I on the right track?
Also I may have used the wrong ATF in the last flush, which I vaguely recall was type F. Am I screwed?
I forgot the technical name of mine, but its the common 5 speed manual they attach to the 4.0 OHV...
rusty ol ranger
2.9 Mafia-Don
7,492
Michigan
177 CID
Drain the type F, dump some lucas in with the ATF, and try again.
But yes you may have eaten a syncro.
Its a M5OD btw. Lol.
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Ford has changed the recommended fluid in the M5OD so many times over the years that it’s not worth counting. If they can keep changing which fluid you’re supposed to use in the older ones, you pretty much can’t screw it up... as long as you put ATF in it.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Yes my problem is the conflicting search results of recommended fluid. I have a bunch of synthetic dex/Merc, will try with some Lucas. Might hit up my transmission shop owner buddy.
racsan
4,441
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
try reving the engine with trans in neutral (clutch out) between shifts, my 93 I had to do that when downshifting from 3rd to 2nd. Upshifts were fine. As long as you didn’t use gear oil you should be ok. I run pennzoil syncromesh fluid in mine with no problems.
Roert42
4,959
Kintersville, PA
Ranger XLT
4.0 SOHC
Current spec for that trans is going to be mercon V.
Try matching your revs when you shift, see if it helps the grinding.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Yea I think I'm gonna go mercon V. Actually my downshifts are fine, it's the upshifts thats the problems. Actually both ways it's goes through the gears fine, just grinds it if I shift not super slow and easy.
fastpakr
2,832
Roanoke, VA
Is it possible you've got a dragging pilot bearing or hydraulic issue?
Junk Collector
Truck of Month
4,800
Rapid City SD
If all gears are grinding I would suspect something like fastpakr said. It's not uncommon to lose a synchro or two but all of them at once would be really rare.
5w30 engine oil is worth a try too. It was almost a miracle cure in one of mine that was a little weird going into 2nd gear.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Hydraulic feels fine. Engagement is good. Pilot bearing might be something. I didn't consider that.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Well everything but 5th. 3rd ain't so bad either...2nd is the worst, followed by 4th.
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
You could be having slave or master cylinder issues causing your problem. I was having shifting issues with mine before the slave decided to take a dump. I ended up getting a complete, bench bled kit with the master and slave cylinder in the kit. It solved my shifting issues after I changed them out.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I do have a brand new pre bled unit from a previous parts toss...if I can find it I will swap it lol
ronclark
25
Woodland, WA
95 4.0 with 93 ECU
I have used Pennzoil Synchromesh Manual Transmission Fluid in my M5OD's, the shifting is way smoother than Mercon V.
