5 quarts instead of 4.5?
03ranger30
5
Mount Airy, MD
3.0L V6
Well the time has come to change my oil for the second time. The owners manual calls for 4.5 quarts of 5w-20. I bought the 5.1 quart jug from Advanced. Will it hurt if I put all of the oil from the jug in? Cause it is kind of a pain in the ass to pour some and then measure it all out.
Thanks
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Is it really that hard not to pour the whole thing in the engine? Pour most of it in, fire it up and check it. If it needs a splash more add it....
03ranger30
5
Mount Airy, MD
3.0L V6
I just think its a pain, and I usually just end up throwing the extra out, and its expensive oil.
RangerFabWorks
The O.G blackwidow67
710
Lexington, North Carolina
302
it should be 4.5 quarts without filter change and 5 with.
but yes. even a half a quart is not good for an engine. its that much more stress your putting on your oil pump.
03ranger30
5
Mount Airy, MD
3.0L V6
so i can put all 5.1 in then
03ranger30
5
Mount Airy, MD
3.0L V6
Alright then, thanks
pcollins
7
Middle of Nowhere, NY
GMC
4.8L
stress on the oil pump is not why overfilling an engine is bad. When you overfill the engine the Crank starts to splash in the oil causing foaming, which
A) Builds pressure and can blow out the rear main seal
B) The Foamy stuff gets sucked up and doesn't really lubricate anything, thus wearing your engine. Quick.
But theres normally about a quart leeway before the crank starts hitting the oil.
James86
10
55381, Minnesota
2012,
Ford,
Ford,
3.0 Flex Fuel, 2.5L, 3.3 Flex Fuel
WHY DO I KEEP BUYING DODGES?!?!?
I put in 4.5 quarts even with a filter change and its smack in the middle of the marked section :dunno:
I just save that 1/2 quart and in 4 changes, the 5th is free more or less :D
RangerFabWorks
710
302
this is true also. but over working your oil pump is not good either.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
dankhimself
Northern NJ.
I fill my oil to the top of the cross hatch on the dipstick, my 4.0 liter takes 5 quarts exactly with motorcraft FL-1A filter.
Edit: didnt realize you had a 3.0, its probably different
Froggmann
5
In my House
3.0FFV
5 quarts in mine puts it right at the full mark with a filter change.
03ranger30
5
Mount Airy, MD
3.0L V6
I just put 4.5 in and its right in between the lines, and the oil pressure is fine
