- Aug 7, 2007
- 0
- IL
- Ford
- Engine Size
- 302
I'm looking into swapping out my stock tank in my '84 ranger for a 5 gallon one and was wondering if anyone has done something similar, and if so what tank did you use? I use the bed on this truck so I don't want to cut any part of my bed or mount it in the bed and I want to use the stock filler. I have a 3 inch body lift so I should have a little extra room too. I only use this truck off road and don't drive it long enough to need more than 5 gallons at one time and don't like to add more than that because of the crappy ethanol in the gas (10%). The last time my truck wouldn't start I couldn't figure it out and decided to syphon some gas out to see how it looked and it looked identical to antifreeze and it was definitely all gas it just got old quick, which is what ethanol gas does. Since then I have to clear out the idle passage in the carb nearly every time I use it so I want to get rid of that tank plus if I climb some hills with less than 5 gallons in the tank and don't make it up quick I run out. thanks for any ideas.
