- Jun 2, 2012
- 8,370
- canada
- Ford
Yes, that is correct
Shift motor should rotate to all positions when plugged into the harness whether its bolted to transfer case or not
There are no internal sensors inside transfer case, everything is in the shift motor, and no "ground" to transfer case is needed
When activated the controller starts to move the shift motor and then "watches" the contacts to make sure they are changing, if it doesn't "see" that, it stops and then reverses back to where it was
And it should Flash the 4WD lights at that time, indicating a problem
From your description
The switch on dash is OK
The fuses for shift motor and controller are OK
The shift "motor" is powering up, and moving in BOTH directions
But controller is not "seeing" contacts in the shift motor changing so doesn't "know" what position transfer case shift rod socket is in
