Jordan94
- Aug 29, 2007
- 0
- Age
- 33
- Canada, Ontario
- Mazda
I have a 3.0 V6 motor out of my 94 4x4 truck but the wiring harness is tad bit different from what I believe was a 2WD automatic motor that I'm putting in, Iv switched them up and put original harness on the 2WD drive motor so when it goes in the hook ups are where there suppose to be. I noticed the Air Temp Sensor on the newer motor I'm putting in had a sensor on the intake manifold so I took it out and plugged it, the air boot had one in it. Also the harness on the 2WD motor had only one link for one O2 Sensor, I needed 2.
I will need to get a Pilot Bearing for the crankshaft on the 2WD auto correct?
I hope I'm doing this right, if anyone has any tips or concerns on a problem that
I might run into please post - its my first motor swap.
Thanks
Thanks
