- Dec 14, 2008
- Reaction score
- 0
- Make / Model
- Ford
- Automatic
1)the year of your truck?
1996 ranger Extended cab
2)What engine?
4.0 l
3)Which transmission
I belive its the 4r55e
4)2wd or 4x4?
4x4
4-a) if it's a 4x4 is the T-case Manual or Electronically shifted?
electric
I Have a 96 ranger with what i belive is a blown 4r55e( i can check trans code tommorow) I have pulled a full trand from a explorer (includes started flexplate and torque convertor. I have researched and found that the trans can supposedly bolt rite up into where my old trans was. However there will be extra sensors but i dont need to use them. I have also read that you need to switch the valve body or epc ( i would rather switch the epc because puting a blown transmission valve body into a good trans doesnt sound to good to me.) I have also found out that this trans is much stronger then the 4r is.
So
Basicly i need to know for sure
1) will this fit and work
2) can i use my 4r55e's transfer case
3)can i just switch my epc to make this work
4)Will the overdrive work corretly in my 96
5) will the gear ratios that are driven with overdrive work correctly
I have some info from people here http://www.explorerforum.com/forums/showthread.php?t=222466
( i hope i can post that) but i want more info.
I am really hoping that this will work, and work correctly. I have spent about a day pulling the trans and realy want to have a drivable ranger. I bought my truck for 650 with the blown trans, a new motor put in 30k ago, 31's, 3.73's,and limiited slip.
If this wont work how hard is a 5 speed standard swap?
If all else fails ill have the 4r55e rebuilt.....
Thank you in advance
2)What engine?
4.0 l
4)2wd or 4x4?
4x4
electric
So
