4R44E to A4LD
ranger_mclaren
76
Bellefontaine, Ohio
2.3/2.0
Ok, I'm in the process of getting a '95 ranger 2wd with a 2.3 and a no tranny. Per the tech library it would have a 4R44E tranny. The previous owner couldn't find one and gave up and was going to junk the truck. This is where I came in the picture I went searching for a tranny today but the junk yard only had three 3rd gens. '93 '94, '95 all 2.3 2wd. The '93 was a 5 speed and the '95 was taken already. So I took the '94s with no way to ID the tranny on the spot I didn't study too well, oops. Anyway I got it home and looked it up and it's a A4LD can I still use it if I change the harness? What all needs to be done to use it or should I just take it back ( I got a 30 day warranty) and keep looking for a 4R44E. Thanks for the info ahead of time.
fix_or_repair_daily
SW PA
Ford,Chevy,Satu
2.3, 5.7, 1.9
If it were me, I would take that trans back and start collecting parts to swap in an m50d as long as you don't mind driving a stick. Auto transmissions really suck the power and gas mileage out of 4cyl rangers.
Josh
4.0B2
151
Walls, MS
4.0 v6
i agree. i don't have issues w/ my a4ld at all. but when its a 4banger, i'd say 5 speed it. now if that's not an option-- for simplicity sakes, i'd still take it back and find what goes in there... unless you're pretty certain you can't find one then just use the a4ld
ranger_mclaren
76
Bellefontaine, Ohio
2.3/2.0
I've seached there invatory they don't have what I need so I am stuck with this for now. What all do I need to use the tranny in place of the 4r44e. I thank I can do the wiring but what about shift linkage and the two lines runniing into the passenger side. Sorry I am clueless with this stuff.
4.0B2
151
Walls, MS
4.0 v6
i can't help you either...not on that.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
The only way I could see this working is if you didn't hook up any of the electronics. You would have the first 3 gears working, but you won't have 4th gear and you won't have torque converter lockup. The computer will also throw a fit when it doesn't see the 4r44e there. You could swap in a computer for a manual trans though.
koda6966
61
The green part of NY.
2.9
I ran my A4LD bone dry for about 6 months. Still shifts fine. :thefinger:
Personally though, I would take the A4LD back if you can, and wait on a 4R44E since it would be too much work to figure out the new trans.
Will the bellhousings even bolt up?
pcollins
7
Middle of Nowhere, NY
GMC
4.8L
I wouldn't put an A4LD in the truck if you don't know the history. You'll be doing all this work again within a year most likely.
koda6966
61
2.9
It's funny, 90% of the people who talk down on the auto trans don't own one.
Mine has well over 200k miles on it, and was ran dry for a few months a couple years ago when I didn't realize it was leaking. Finally figured out when it hesitated every time I stopped. :thefinger:
ranger_mclaren
76
Bellefontaine, Ohio
2.3/2.0
Well I can't return the tranny for cash it's parts only. I must have missed that, anyways I've got 30 days to return it so hopefully the get in another '95. While I wait I'm gonna search around other places for one too, in which case I should find one and get it I'll exchange the a4ld for parts for my focus insted.
pcollins
7
GMC
4.8L
I knew someone would say something like this. I own an automatic, AND a 5 speed truck. I'm in both worlds (much preferring the 5 speed because it absolutely DESTROYS automatics in the snow, nothing to do with longevity). Let me re quote my previous post. And read the bolded words this time.
Majority of junkyards have the engines and transmissions just tore out of the vehicle with no care taken, and then they sit outside in the weather. no one knows the previous maintenance history.
koda6966
61
2.9
Only an idiot would buy a trans from a place like that, and you can easily tell most of the history from a brief inspection.
Only people who don't know how to control the pedals need to abuse their transmission to drive in the snow.
Only an idiot would buy a trans from a place like that.
Or someone who has no intention of putting it in their vehicle without rebuilding it first.
koda6966
61
2.9
Even with a complete rebuild, I'd still want a housing with little to no rust/corrosion on the inside.
Although I did consider rebuilding the tranny from my dad's bronco, ended up scrapping it instead. Didn't feel comfortable rebuilding a trans that sat on a dirt floor in a garage for 20 years.
pcollins
7
GMC
4.8L
Who said I need to abuse my transmission to drive good in the snow? I can downshift with a 5 speed and almost completely eliminate the sliding that happens with most automatics, and not even need to pump my brakes. And I know how to rev match, so theres virtually no clutch wear. Plus I can rock the truck back and forth if I ever get stuck (**** auto hubs-glad i ditched them) and while it may wear on the clutch, it won't do nearly the damage that does to an Auto. i've dissected a few Autos that were rocked back and forth, probably longer than healthy but still...clutch plates welded together, drums warped, bands shot.
And where else am I suppose to buy a transmission? theres only one junkyard in my area, and not all of us have the money to have one shipped to the shop/house. I don't replace automatics on my own vehicles anyways so I won't have to deal with this. I throw in a 5 speed once the Autos totally dead. I'm not hating on Autos, everyone has a preference. And when I'm backing a loaded trailer up a steep hill i'm extremely glad I have an auto.
Kirby N.
March Truck of The Month
