100Timelord
- May 10, 2021
- 4
- Waukesha, WI
- Ford Ranger
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 2WD
I have a 97 Ford Ranger 3.0 automatic (2wd), Transmission designator 'T', so 95% sure it's a 4R44E transmission.
Here's my issue: Every once in a while the transmission will seem to slip out of 1st gear (engine revs up as if in neutral, then transmission engages after a few seconds once I let off throttle). This happened when accelerating from dead stop, and accelerating after braking (under 10 mph) but not stopping completely. Problem has so far only occured when warm, but I've only driven it a couple of times since this problem started.
Fluid level is good and fluid seems clean, but I just recently bought the truck and the previous owner may have changed it.
Take this symptom with a grain of salt, but I've noticed a "whirring" sound when in reverse (intermittent as well). Sounds like a tiny jet taking off.
Just had it in the shop to get the ECM replaced, and they did not detect any transmission issues [they checked the fluid and a short test drive].
Any help/possible fixes would be greatly appreciated.
**to clarify, issue was present prior to (and after) ECM change, so I don't think it's a computer issue
