4.10 gears on limited slip 7.5 differential
Glen MC
Arkansas
Ford Bronco ii
Hello everyone, I am wanting to put 4.10 gears 84 Bronco ii in my 7.5 limited slip rear end. once I put the 4.10 ring gear on my Differential that had 3.75 gears I cant get the pin in. the Ring gear seems too thick to allow the pin to go in. I have a 5 speed Trani 4 wheel drive. Thanks for any help you can provide to fix this or any alternatives. I'm not sure which other rear ends will fit if I need to go that route."
Rock Auto 5% Discount Code: BD8D9A3814E19D Expires July 5th, 2022
Blmpkn
2,380
Southern maine
Ford ranger
2.3 EcoBoost
2.3
2.5" level
Your re-gearing the front too correct? If not... don't use that 4x4.
sgtsandman
Aircraft Fuel Tank Diver
Forum Moderator
6,024
Aliquippa, PA
Ford Ranger XLT
4.0 SOHC
Pre-2008 lift
31X10.5R15
A tooth or two needs to be ground down in the back to make clearance for the pin to go in. It’s a proven practice that works.
Alternatively, there are pins out there designed for lower gearing like that. If I remember correctly, the center is dished out some to allow the pin to clear the ring gear.
bobbywalter
TRS Technical Staff
2,664
woodhaven mi
FORD mostly
BIGGER
sawzall?
Just nibble it wit a die grinder or file ..roto zip ..
ecgreen
266
Dunbarton NH
Ford Bronco II
3"
I got pics from when I did mine. Hold on a sec
ecgreen
266
Dunbarton NH
Ford Bronco II
3"
I used a demel and it worked fine. Pic the side thats going to need the least amount of removal, then slowly start grinding the teeth down. Keep checking to see if you can slide the pin out every now and then. Keep doing this until it just slides out. Clean up and make sure everything is smooth and free of shavings. I have 1000+ miles on this gear and no issues at all.
Mechrick
54
Las Vegas
The other option is a notched pin. The notch is so the pin can be installed before the ring gear. You rotate the pin left and right so the axles can be pushed in and the C clips installed, then turn the pin 90 degrees and install the retaining bolt.
There is a running debate on which is stronger, grinding teeth on the gear or grinding (replacing) the pin. In your case, I would say swapping that 7.5 with an 8.8 is the answer.
.38spl
46
Lake Barkley, Kentucky
2.9
6”
33x12.50x15
James 1:19
My 7.5 came from a 1985 2.8 Ranger, and is a factory 4.10 L/S. It has a notched pin, I'm assuming is factory.
gaz
323
Wa, Bremerton 98310
Ranger 2.9l, BII 4.0l
Ranger 6", BII 4"
Ranger 5sp, BII A4LD
Ranger 32", BII 28.5"
ecgreen,
Genius pics!!
