4.0 valve train
Danger.
PA
Hey guys, i just joined here hopefully you can help me out
I have a 93 ranger and i did my research and know they have lube issues in the top end, it all started in the winter it would make a quick 7 or 8 taps then it would be gone now my ranger makes a ungodly rattle when i am at high way speed (60+) and it gets put under load either accelerating or going up hill, i just wanted to make sure that i am on the right track and if anyone has used the delta cam package how it worked out, i seen on another site that a guys rocker arm blew apart. so any help is appericiated.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Sounds like it's pinging. Valve train noise really doesn't change with load.
spraymonkey
Ive heard that EGR issues can cause pinging, but that should pop a CEL.
Danger.
PA
well its not really a ping...there isn't really a way to describe it other than metal on metal slapping
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Pinging doesn't describe the sound, it's short for "pre-ignition". Ungodly rattle under load=pinging. If it goes away with higher octane gas it's pinging for sure.
Danger.
PA
well i feel like a idot.
daniel3507
73
NE Oklahoma
2.3 EcoBoost
I havent had problems with the delta cam rockers and pushrods. Still have a little noise but I am pretty sure thats from the lifters and not the rocker arms or pushrods. I used to have a bad ping or rattle underload and on highway. Replaced the lower intake manifold gasket which helped a lot and then a new MAF stopped the little bit that was left. Try high octane gas or a basic tune up. New fuel filter, plugs, wires, clean the MAF etc.
