4.0 swap ahead
four.on.the.floor
12
knoxville TN
bronco 2 xlt
I have read and read and read about installing a 4.0 in my 1990 B2 fm146 2.9.
What is something that you told your self that you would do differently if you had to do it again !
Thank you
snoranger
Professional money waster
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Junk Collector
Truck of Month
4,796
Rapid City SD
You have just about the most ideal vehicles possible to do that swap... the only thing you're going to run into is the auto trans wiring if you use your 5 speed and I'm assuming you will. Easy to overcome that issue. Start swapping!
BlackBII
Ranger Custom
Truck of Month
982
UT
If you can, I recommend replacing the oil pan gasket(with a hefty amount of ultra black silicone), valve cover gaskets, exhaust manifold gaskets, spark plugs, water pump, rear main seal, etc. while you have the engine out. It's much easier than doing it while it's in the truck.
If you are going with the manual trans, make sure you get a 4.0 flywheel, clutch and starter. The FM146 should be fine behind the 4.0 for a while, provided you don't abuse it. You may want to look into getting an M5OD
snoranger
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Just wondering why. I cannot turn my 33s very well past 60 going up a grade even at 5k rpms. I live in Knoxville Tennessee and it is very hilly.
Because he’s in the 2.9l mafia.
four.on.the.floor
12
knoxville TN
bronco 2 xlt
So there no reasoning other than he likes the motor ? I guess someone has to love it. I mean it could be a good turbo motor I guess ? Lol
rusty ol ranger
2.9 Mafia-Don
7,485
Michigan
177 CID
Id regear if it were me. A 4.0 still isnt gonna be happy under those conditions.
I am a proud 2.9 flag waver, but every 4.0 ive ever driven didnt really feel gutsy enough to justify ripping out a running 2.9 for.
rusty ol ranger
2.9 Mafia-Don
7,485
Michigan
177 CID
How much different would a carbed 302 be ? Vs a 4.0.
Stock for stock? Not much better.
But a 302 can be built to be damn more potent then a 4.0.
Or get a 94+ roller 302 and convert it. They had 40 hp and 55ftlbs on a OHV 4.0.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
The only thing I can say about it...is a question....is
why was it not in there the day it was built ???
For driving in your conditions ...which I know well and have driven a 2.9 and my 4.0 broncos in the same place...the difference between a 4.0 and a 2.9 is the difference between a 460 and a 351.
Huge casm in how the engines actually work under load. On paper it looks close...in reality it's huge. Probably would not have swapped a v8 into my truck if it was equipped with a 4.0 and a manual the day I got it. Instead of the 2.9 and a-frail-ld fail o matic.trans.
The 2.9 5 speed is great in a b2....4.0 is fawesome.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
My 2.9 is in my truck.
My 4.0 is on the scrap pile.
You do the math.
snoranger
ASE Certified Tech
13,653
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
