4.0 SOHC coolant loss
buell-eyed-devil
21
Wesley Chapel,Florida
FORD
5.0-ZF in process
3"body on new poly body mounts
Hey ya'll, watch this
my application only uses 1 sensor. will this work?
sheep herder
1,024
sheep pen
If it ain't broke, break it.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Yes, just be sure to order the version of the Aluminum ThermoStat Housing
that has 1 TempSensor, pick either ClipMount or ThreadMount,
& appropriate RadiatorHose outlet routing, ForeHand or RightHand.
8,369
And worst case you can just put in a 2nd sender/sensor to seal the hole and not use it
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
buell-eyed-devil
21
FORD
5.0-ZF in process
Whats the best way to get all the air out of system?
Roert42
4,948
Kintersville, PA
Ranger XLT
4.0 SOHC
Typically, I would just fill the radiator, squeeze the upper rad hose while filing to help work the air out, then when I can't get anymore air out I run the engine and fill the rad some more. Keep the overflow full, and check the radiator every time I go to start for a few days.
ericbphoto
Overlander in development
16,538
Wellford, SC
6"
For me the heater core hoses are a high point. I installed a flush tee in one of them. That way I can loosen the cap on the tee and allow air to escape.
8,369
+1 ^^^
Remove either heater hose at the firewall and fill until coolant starts to come out of hose and core
buell-eyed-devil
21
FORD
5.0-ZF in process
That's the way I've always done it but haven't seen flush tees for a while
buell-eyed-devil
21
FORD
5.0-ZF in process
cbxer55
767
Midwest City, Oklahoma
After I swapped the housing n my 4.0 Mustang, I just filled it and checked it every time I drove it for a few days. When the level in the overflow tank stabilized, I assumed it was full and haven't messed with it again. The heater hoses get hot, so they must be full.
gw33gp
536
Costa Mesa, CA
4.0 SOHC
33"
My driveway has an incline and I fill the radiator with the front up and that usually works well. I check the reservoir after driving and cooling down. I add coolant if it is low.
buell-eyed-devil
21
FORD
5.0-ZF in process
got the old housing off. 2 of the 3 mounting bolts broke off 1/2 from base. cant find anything to grip the broken bolts. Been spraying with blaster and have been trying vicegrips with no luck. Thought about a propane torch but aluminum head is not a good idea. Any ideas?
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
...old housing off. 2 of the 3 mounting bolts broke off 1/2 from base.
...cant find anything to grip the broken bolts.
...spraying with blaster and have been trying vicegrips with no luck.
...ideas?
Cut away old plastic ThermoStat Housing with tin snips.
PenetratingOil soak broken bolts overnight, then try ViseGrips again.
If that dont work, cut bolt flush with engine block, small bit drill into broken bolt, use LeftHand remover.
If that dont work, drill out broken bolts & ThreadTap holes for slightly larger bolts.
AntiSieze for the next guy.
Patience + persistance needed.
